How can I do successive rotations on an object using picture 3d labview 8.5
I used to use Labview 7.1 and I am trying to go to labview 8.5. My problem is that when I want to do successive rotations on the same object using picture 3d with labview 8.5 it does not work whereas it was working with labview 7.1.
Basically, what I want to do is first a rotation around the axis X then Y and finally Z. This 3 angles give the absolute orientation.
What am I missing?
Thanks for your answer
Boris
(2,850 Views)
Are you using an example? If yes, witch one? If not, can you send us your code?
(2,793 Views)
