How can I do the USB connection between PC and TDS2024B osilloscope
hello
I write a labview program for controlling TDS2024B osilloscope and mesuring voltage with this program. I want to use USB to connect PC to this osilloscope and control it with labview program. my problem is : there is no visa open for USB in labview. how can I do the USB connection between PC and osilloscope.could you help me please?
thank you.
(6,263 Views)
There is only one VISA Open. The type of device is defined by the VISA Resource Name. If the scope is USBTMC, then it will appear in MAX and all you have to do is click on the little arrow on the right side of the VISA Resource Name control and select it. You should also be using one of the drivers available at http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=542.
(6,246 Views)
