How can I download Real-Time Module 2018, not SP1.
Hi all.
My computer have Labview 2018 and I have to install Real-Time module 2018 which is compatible with Labview 2018.
But the download page (https://www.ni.com/ko-kr/support/downloads/software-products/download.labview-real-time-module.html#...) does not have 2018 version and only provide 2018 SP1.
I tried to install 2018 SP1 but the error message says 2018 SP1 is not compatible with 2018.
Where can I download real-time module 2018 version not SP1?
(4,067 Views)
Do you use 64bit LabView or 32bit?
Best regards.
(4,030 Views)
Hi. Thanks for your reply.
I'm currently using 32 bit version.
I always have to install real-time module 2018 using myRIO software bundle that includes RT module, which is quite annoying.
Best regards.
(4,001 Views)
I think the only way is to upgrade the LabVIEW to the version 2018 SP1 32 bit.
In the link below you can see system requirements for Real-time module.
  https://www.ni.com/pdf/manuals/374714j.html
And in the link below you can see in which case you can upgrade to SP1 version.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OAgSAM&l=en-US
Best regards.
(3,990 Views)
