How can I draw a line/arrow in control panel in Labview6.1
hello,I want to draw some lines and arrows in Control Panel(front panel) for demonstration/notes.Can I do this in Labview6.1?
(5,825 Views)
Im not sure about labview 6.1 but if you look in controls and decorations there are arrows and lines in there, at least in 7.1 there are.
Otherwise if you go to paint, or whatever drawing program, you can make any arrows or lines you want and simply select them and copy and paste the images on the front panel.
Hope this helps
(5,825 Views)
Both thick and thin arrows/lines are on the decorations palette. You can pick either end to rotate or stretch.
(5,825 Views)
Look for a palette named 'Decorations'. It contains many lines and frames to help with panel layout. See attached image.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(5,825 Views)
"controls and decorations " stuffs work for labview6.1. sorry for the silly question and thanks a lot,NIDave.
(5,825 Views)
