How can I draw a sin function graph
i only want to input an x and then sin function caculates its value and send it to graph control.
How can i do it?
(5,749 Views)
in structure mathemathics u have sin(x) ,use for loop from 1 to 90 degree make array ,give input to graph and charts
(5,749 Views)
(5,749 Views)
Note that the sin(x) function is in radianss. You need to convert it into degrees. To do that please view the attached sample VI I wrote. Good luck!
(5,749 Views)
