How can I draw flipped text in LabVIEW's Picture Control?
I'm trying to draw flipped text (rotated 180 degrees) using LabVIEW's Picture Control. LabVIEW's "Draw Text at Point.vi" can do 90 degrees in either direction with its "text orientation" input, but not 180 degrees.
How can I do this?
(2,759 Views)
Hi bmihura,
seems you need to draw that text in standard direction and "rotate" it on your own. In your case you only need to flip it in both direction, horizontally and vertically…
(2,739 Views)
