Let me explain my case:
- I have an array of data that represents a SINGLE record of a database table (columns contain: data label, data, data type; rows contain: the fields).
- I have to create as many indicators as fields are on the query (notice that there are different type of data, so it's necessary that the indicator should be of the same type, but that's another problem).
- As the number of fields vary on the query, I have to create the same number of indicators.
How can I do that? (Hiding the controls can be a solution, but it's limited to a max. number of fields)
It's clear we are talking about a common loop. But which is the function/control/whatever that can be used to dynamically create
the indicator/control?
Thanks in advance.
Mauricio Vidal
VIDAL & ASTUDILLO Ltda.
http://www.vidalastudillo.com
