How can I dynamicaly select a column from a table in labview
I am trying to develop an application to do the following:
1- Dynamically populate a table in labview from a source ( it can be an array in Teststand or a .csv file). I think I can do this step
2- While the VI is running the user can edit the data by a drop down box on each cell (I need help on this part)
3- The user can select a column by checking a Checkbox on the far left of the table or by clicking anywere on the row and select multiple rows ( I need help on this one)
4- The user will click Go and the VI shall return the indeces of all the rows that are selected in an array of numbers. ( I need help on this one)
5- After step 4 is done, TS is called to run sequence files specified by each row of the table in labview. (I maybe able to do this step)
I appreciate any help in this.
Sam
(3,932 Views)
OK
This has been asked many times in this forum. There is no built-in editing that does this - you have to do it yourself. If you do a search in this fourm you will come across the various solutions that have been proposed and implemented.
Define "select". Do you mean highlight a row?
The SelectionStart and SelectionSize can return to you what's selected if you choose to use this method.
OK. Can't help you with this anyway since I don't have TestStand.
(3,923 Views)
