How can I edit data in Microsoft access using ActiveX
I've tried to modify Read Access DB with ActiveX to edit an entry in my database, but I get the following error
Exception occured in DAO.Field, Update or CancelUpdate without AddNew or Edit..
(3,672 Views)
As I remember, you have to call "EDIT" method before trying to modify something in DB.
(3,672 Views)
When do you call the edit method. In VB, I can use the following code to do the required manipulation
With Recordset_
.edit
(manipulation)
.update
end with
Can you help?
(3,672 Views)
Did you try to do the same thing in LabVIEW (the same order, after you have the right reference to the recordset). I know this kind of problem from VB too. I didn't try it in LV but I supposed it should be the same.
Let me know if it doesn't work.
(3,672 Views)
I've tried desperately to get it to work, but I've had no luck. I want to edit the last record so I MoveLast, Edit, then I go to Fields, then _Field,and then write the value. I always get Invalid DAO.Argument
(3,672 Views)
(3,672 Views)
Can you send me (labviewer@yahoo.com) your VI and database (or something that simulates the problem)? ... my Office is 97.
(3,672 Views)
