How can I eliminate spaces from a file?
That's odd, it works just fine here, see image! (I have enabled "\codes" for the string constant for convenience).
Make sure to grab "all rows", not just the first. It's a 2D array.
(btw: Trim Whitespace is in the "Strings...Aditional String Functions" palette, lower right corner, but you don't need it if you just have single spaces)
Message 11 of 13
(546 Views)
Check in the online LabVIEW help under "Backslash ('\') Codes Display"
In "\" Codes Display, byte values/characters in the string which are non-printable appear in the form of "\xx" where xx is the hex value for the byte/character �
with a few exceptions which haven't changed since LabVIEW v1 or v2 (since ASCII code hasn't changed):
\r for \0D (Carriage return), \t for \09 (Tab), \b for \08 (Backspace), \n for \0A (Line feed), \s for \20 (space), \\ for \5C ("\" character itself).
Type "\20\0A" into a string control that's config'd in "\" Display, hit enter and it'll change itself to "\s\n".
A string "000D 2001 4142 FF1C FA26" in Hex Display
is "\00\r\s\01AB\FF\1C\FA&" in "\" Display
The usefulness of
"\" display is apparent if you ever need to have a string constant of just "\s" on the block diagram.
Fading out. " ... J. Arthur Rank on gong."
Message 12 of 13
(546 Views)
Thanks! that helps alot.
Message 13 of 13
(546 Views)
