How can I enable spectral stitching technique with FPGA modules?
Hi all,
I have a hard time implementing LabVIEW project with several products like FPGA 7975s, 5791RFs, and some else.
I really want to expand my LTE system's bandwidth, but I'm not sure how to figure it out. (5791's instantaneous bandwidth is 100MHz, and I want to make it higher)
Meantime, I saw the patent about 'spectral stitching' that NI implemented in 2016 and showed at NIWeek. (https://patentscope.wipo.int/search/en/detail.jsf?docId=WO2016061003&recNum=1&tab=Drawings&maxRec=&o...)
I wanted to get more information but I think there is not enough.
Would you please tell me any further information, or codes, or any other ideas about spectral stitching? or expanding bandwidth?
I need your help.
(2,705 Views)
Accepted by topic author Soom_in
Hi! Unfortunately the source code for the spectral stitching technique that we demonstrated at NIWeek 2016 is fairly specific to the hardware being used, and I expect it would not be trivial to implement for the 5791. If you could send me a direct message with your contact information, I'd love to discuss your requirements / application in more detail by email.
Rob B
FlexRIO Product Manager
(2,660 Views)
