How can I execute the test case written excel sheet
Hello
I have written the test cases  in excel sheet. Please tell any one how to execute test case from labview.please send some sample vi
Message 1 of 11
(5,189 Views)
Have you written you test cases in VBA coding for excel or something else.
Can you please explain bit more about it.
Message 2 of 11
(5,187 Views)
Its written in vba
Message 3 of 11
(5,176 Views)
Have a look on this link, might help.
http://zone.ni.com/devzone/cda/tut/p/id/2828
Message 4 of 11
(5,170 Views)
I'm sorry, but you've provided zero information on what you have. All you've said is that you have an Excel "sheet" with test cases, and that it's written in VBA. What does that even mean? What's written in VBA? Are you trying to call the VBA code? Are you trying to rewrite the VBA code in LabVIEW? Unless you provide a better explanation of what you have and what you are trying to do, we can just keep playing a guessing game.
Message 5 of 11
(5,166 Views)
My question is, is it possible to execute the particular cell in excel sheets in  which test conditions are written
Message 6 of 11
(5,157 Views)
You can't "execute" cells. You can only execute VBA code. Thus, your question makes no sense.
Message 7 of 11
(5,149 Views)
Thanks for information
Message 8 of 11
(5,143 Views)
You can make DLL file of your VBA test cases and call from LabVIEW. I think you cant directly call VBA code from LabVIEW. Share your code to provide you more help.
Message 9 of 11
(5,135 Views)
You can via ActiveX by using the RunMacro method.
Message 10 of 11
(5,128 Views)
