I found the other day that there are instructions included inside the Read From Spreadsheet vi on how to modify it slightly to read strings rather than doubles.
If you drop the Read From Spreadsheet vi onto the block diagram and double click on it, you will open the front panel for the vi. If you then select the block diagram (for Read From Spreadsheet) you will see an 'instructions' frame below the main 'code', and the 3rd paragraph tells you how to modify the VI to read the spreadsheet as a set of strings rather then doubles. Save the vi as a new filename when you've edited it or you will overwrite the existing vi!
Using the newly modified vi you can read in your entire spreadsheet, extract the dates as strings, then do any conversion necessary to the other columns of the sheet to change them into the types of value you require (eg doubles).
I hope this helps.
Mark
