How can I find ETS operating system?
How can I get ETS? can I have a free version or trial one?
Regards!
(3,098 Views)
Do you mean the LabVIEW realtime ETS or something else?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,086 Views)
Hello, I would like to change my NI PXI 8106 controller into a real-time target, I am really confused I should installa a real-time operating system, or just formatting the hard disk as FAT32 file system and then booting it using floppy disk.
Best Regards!
(3,054 Views)
Accepted by topic author Azzam87
Hi Azzam87,
part of your question was answered in your parallel thread:
I have NI PXI 8106 controller (regular non RT), can I install Real Time operating system
http://forums.ni.com/ni/board/message?board.id=270&message.id=6825&requireLogin=False
You can try LV Realtime module for 30 day. Download this module, instal on host computer and after that install RT on PXI.
Follow this KB:
How Can I Make My PXI Controller a Real-time Target?
http://digital.ni.com/public.nsf/allkb/21C45EF391059C2A86257241005CA814?OpenDocument
Simply prepare your PXI. Convert to FAT32, after that create the USB boot flash disk in MAX.
Boot PXI from USB. Install the base of RT on PXI with this USB utility. After that boot PXI to RT and install the rest of software with MAX.
See:
PXI Installation/Configuration
http://www.ni.com/support/install/install_hardware_5.htm
Jiri Keprt
NIE Czech Republic
CLA, CTA
(3,027 Views)
