How can I find out if the logged in windows user is adminstrator?
Hi All
I have an app where I wish to disable certain functionailty if the logged in user is NOT an administrator.
Is there a straightforward way to determine this. I cant find an Application property that returns this value,  i know it may be accessible from the registry but I have not been about to find out where and what to look for.
All help much appreciated.
Regards
Tristan
(3,686 Views)
Right click on the START button. If you see "Open All Users" rather than just "Open," the account is in the local Administrators group.
(3,682 Views)
(3,675 Views)
Sorry people I wasnt clear enough. I need to determine this programmatically within labVIEW..
(3,647 Views)
The solution muks linked to should work. You just have to be aware that if you are running vista/windows7 with UAC turned on it will show the user is no admin if he doesn't run labview with admin privileges.
(3,633 Views)
