How can I find special characters in a string
I have a small task where I have to find special characters in a given string, Can anyone suggest.......................
(12,066 Views)
Hi kwan,
you can use the "search and replace" function, "match pattern" or you convert your string to an array of U8 and use some Array functions to do it.
I recommend to see also this link.
Mike
(12,063 Views)
Hi Kwan,
       U could use "Scan from String" function to find any character match
Raja
(12,061 Views)
Hi..
   This may help.......
(12,059 Views)
What is your definition of a "special character", could you be a bit more specific?
Do you simply want to find the position of a specific character in the string?
Can it occur more than once and you want to find all occurences?
What should happen if the special character does not exist?
For programming purposes, all 256 possible 8 bit characters (x00-xFF) can be treated the same. Non-printing characters can be entered in \-codes or hex display if needed.
(12,050 Views)
Thanks for the suggestion, the picture really helps that is what exatly I want.........................Smiley Very Happy
(12,049 Views)
I'm trying to search within a *.txt file and i'm looking for the $ character.
The *.txt contains thinks like these:
datadatadata$variable
I'm trying to extract the name of the variable. Can any one help?
There are about 10 variables per text file and the variable name may be different between files.
Thanks!
EDITION
I found the solution I must add the "\" character to match special characters! Thanks!
Message Edited by ethan85 on 12-26-2008 10:08 AM
(11,771 Views)
