How can I find which VIs are actively running?
How can I find which VIs (among thousands) are actively running (not just reserved)?  (Exec.State property is not enough)
Message 1 of 36
(5,263 Views)
DETTSmiley Surprised
Yes, if you need to do that dynamically- do it!
the Desktop Execution Trace Toolkit, Its not something I have needed to play with but, if I am understanding you correctly you might need to check it out.
Post back, I'll learn something!
Message 2 of 36
(5,231 Views)
Or the less expensive way (not needing the DETT) would be something like this
Message 3 of 36
(5,200 Views)
I think @FermWorks is already aware of this property node, and what she meant to ask here is: any method to get the list of VIs, which are actually running at a given instant of time.
Your solution will all the VIs in memory and has state as 'Running', which mean "VI is reserved for execution by one or more active top-level VIs".
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 4 of 36
(5,186 Views)
I would really enjoy an extensive dialog on this subject. I have found the "running" Exec.State a little confusing. Right now I'm looking at a "Main" vi that is just sitting there waiting for an input to an event structure. It shows 500+ vi's "running" - except the Main vi. Smiley Indifferent
PaulG.
Retired
Message 5 of 36
(5,171 Views)
That's because Main.vi is now "Run Top Level" not "Running"
Message 6 of 36
(5,153 Views)
I'll give DETT a try when I get a chance. I'm troubleshooting on a LV 8.6 system but could load all in LV 11, if necessary. I'll let you know if I figure it out, thanks.
Message 7 of 36
(5,131 Views)
Thanks for the clarification. Doh!
PaulG.
Retired
Message 8 of 36
(5,127 Views)
Can you try this...
http://zone.ni.com/devzone/cda/epd/p/id/2612
Show Running VIs VI:
Hope this might help!
Cameron T
Message 9 of 36
(5,114 Views)
@CamThornton wrote:
Can you try this...
Not quite.  Meg wants "Is Run Arrow Black?" to filter out the reserved vis
Message 10 of 36
(5,102 Views)
