How can I first clear data then save to a file
Hello Folks,
I need help from you.
This is what I’m trying to do:
Whenever I save the .txt file, first, it will clear my current file data and then save new data.
It can be a simple solution, but unfortunately, I could not be able to get it.
Appreciate your effort.
- Reduanul
Message 1 of 16
(3,943 Views)
Hi REDUANUL,
When you want to append data to a file then you need to append that data - instead of overwriting the file or recreate it!
Btw. when there is a problem in YOUR code then you should attach YOUR code. (We cannot debug text/images using LabVIEW…)
Message 2 of 16
(3,940 Views)
So your goal is to replace or create your file.  There is an input on the Open/Create/Replace File node called "operation" where you could set that.
Message 3 of 16
(3,928 Views)
Hello GerdW,
Here are my subVI snipped.
First, I have created a file. After one execution file is being replaced, each time string values are saved but with existing data. Probably here, I need to make some changes (if I didn't get you wrong). But not getting what will be the changes!
Message 4 of 16
(3,892 Views)
Hello crossrulz,
Yes, I did it.
Here what I did:
Everything works for the initial saving operation, but when the second time (and later on) I am saving, data is adding with exiting string values.
Message 5 of 16
(3,887 Views)
You are placing the file pointer to the end of the file therefore you are simply appending the data. Don't set the file position and see if you get your desired results.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 16
(3,883 Views)
Hello Mark Yedinak,
I tried it but not working. Same thing happening (appending with existing file) 😞
Message 7 of 16
(3,868 Views)
If you are replacing or creating a file, there is no reason to set the file pointer to the end.
Message 8 of 16
(3,858 Views)
Hi Reduanul,
What is your goal?
Do you want to append new data to an already existing file?
Or do you want to create a new "fresh" file with each run of that VI, "deleting" the old content and only write the new data to the file?
Your explanations aren't clear until now (IMHO)…
Message 9 of 16
(3,846 Views)
Hello GerdW,
Here is my explanation:
I have created a file as of now. But want to append new data to an already existing file by "deleting" the old content and only write the new data to the existing file.
I hope now it's clear.
Message 10 of 16
(3,822 Views)
