How can I fix this error (Error 1073807265)?
Hello, may I know what this error means? And how can I fix this?
(1,019 Views)
This error seems to be occurred during initialize of Keithley Device and it is failed to establish the communication with the connected device.
Sharing more information will be helpful (What are you trying to do? Connected with what kind of device? what is the interface used?)
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(998 Views)
It's weird because when I ran the Keithley Initialize VI, it can communicate with the Keithley SMU. It doesn't show any errors. I was trying to do a photocurrent spectroscopy run and used a Keithley 2611A SMU, which is connected to the computer via a GPIB cable. The GPIB cables were well-connected to the computer, so, I don't understand why the error appeared.
(947 Views)
