How can I format a second x-axis
Using LabView 6.1 on Windows 2000 Prof.
I'm using a Graph with 2 X-Axis. 2 curves are linked two the axis with the Voltage steps, this axis is formated with a marker-array. another curve is linked to the second axis, with the impuls-numbers. the problem is, that if a test is aborted, there aren't any data for all the impuls-numbers, so they aren't displayed in the graph, but the voltage-steps are, because of the markerarray. so i would like to format the second axis also with a markerarray, but i don't know how to select the second axis with property-nodes.
Hope my question is clear enough 🙂 Thanx
(3,476 Views)
To modify the properties of a second X-axis you have to use the "active x scale" property in the property node. To make changes to the second X-scale's properties set this to 1 before making the changes (0 is the first x-scale).
(3,457 Views)
PERFECT !!! Exactly what I was looking for, thank's a lot.
(3,445 Views)
