How can I generate a gauss function?
Hello together,
I would like to generate a Gauss function. Is there a SubVI. I tryed it, with the SubVI "Gauss Function.vi", but without success.
I hope anybody can help me.
Greetings spaetzelcounty
LV2009
Message 1 of 12
(17,960 Views)
It works fine.
What do you mean by u failed??
What r ur expected input & outputs???
Try "gaussfir (MathScript function)"...i think this is what u r looking for.
Message 2 of 12
(17,948 Views)
Spaetzelcountry,
i assume that you want to display a Gaussian Distribution.
If so, pleas take a look into the example finder and search for Gauss.....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 3 of 12
(17,938 Views)
Yes I mean a Gauss distribution.
Hello Kekin,
It is possible that you post a example with the "Gauss Function.vi"?
Hello Norbert B,
I looked into the example finder and found: "Gauss Mod sin Generation.vi". Do you mean there is a easier way (VI)?
Thanks a lot
zäpfle
Message 4 of 12
(17,906 Views)
Accepted by topic author zäpfle
hi zapfile,
  I am posting the gaussian function i.e exp(-x^2/2).19145i448A77C0F7A2FDD5
Thanks and regards,
srikrishnaNF
Srikrishna
Message 6 of 12
(17,889 Views)
Where can I find this VI?
Message 7 of 12
(17,885 Views)
The VI is under Math->Probability&statistics.
Message 8 of 12
(17,876 Views)
Thanks a lot an everybody
greetings zäpfle
Message 9 of 12
(17,865 Views)
I had the same problem. I found a good solution:
In the end I used the "Gaussian-Peak-Fit.vi"  . It has an input "parameter bounds"; this has to be set to the 4 parameters that define your desired gauss function (center, amplitude, width, offset).
The parameter bounds needs a max and a min-value for each parameter. I just set max=min. (see diagram: 4 values in and 8 values out as a cluster).
The data feed into the Y-input is irrelevant. It is only necessary so that the gauss-fit routine does not complain.
The inspiration for this solution came from the following statement in the help of the Gaussian-Peak-Fit.vi:
"If you know the exact value of certain parameters, you can set the lower and upper bounds of the parameters equal to the known values."
Here is a nice programm:
Message 10 of 12
(17,477 Views)
