How can I generate an Event if an indicator has changed it´s value?
I need do gather some Errormessages of an application (e.g. The application sends "Not Ready" and it´s indicated on the LabVIEW window) because I want to sample them in a History box.
I´ve tried this: First I placed an control (an LED) on the panel and copied the value of the "Not Read" indicator to a property node of the LED.
Then configured the Event structure with the setting "Value has changed" of the LED.
But the Event structure is not triggered only when I set the indicator with mouse..!
Thanx in advance for Help!
(3,214 Views)
What property are you using? In order to fire a user event programatically, you should use Value(Signaling) and not Value.
(3,214 Views)
Hello Dennis,
yes, that works! But it is not edge triggered!
I placed the property node with Value (Signaling), but the event strukture is always triggered. After placing the prop-node in a case structure, it is possible to trigger the event.
But, in the example a "Not Ready" is indicated (an the signal stayes TRUE for a while), the event strukture is run through every cycle!
What am I doing wrong? Is it possible to realise an edge-triggered event?
(3,214 Views)
EMG wrote in message news:<506500000008000000BF000100-1079395200000@exchange.ni.com>...
> application sends "Not Ready" and it s indicated on the LabVIEW
> I ve tried this: First I placed an control (an LED) on the panel and
> LED.
> with mouse..!
Use the Val (signaling) property.
(3,214 Views)
I'm not sure what you mean by edge triggered. It's certainly possible to put a case statement inside the event. You could use the Event Data Nodes OldVal and NewVal to see if there's a change or wire a shift register through to check for a change.
(3,214 Views)
I´ve wired a shift register and checked for dissimilarity.
It works now.
(3,214 Views)
Sorry, can t read the message...
"Paul Cardinale" a écrit dans le message de
news: 64050551.0411120829.5b64ea1d@posting.google.com...
> > LED.
> > with mouse..!
(3,214 Views)
