How can I get a run version of labview for the clients?
Hi all,
I get a program running in the labview. The clients want to run this program without buying a full version. Is there a run version for labview?
Cheers,
Baicy
(2,785 Views)
Accepted by topic author baicy
If you have LabVIEW professional or above, you would use the application builder. All your clients need is the free LabVIEW runtime engine. If you only have LabVIEW FDS, you can buy the application builder seperately.
(2,775 Views)
