How can I get the breakdown of the no. of msgs on the CAN bus for dif IDs?
Using the examples in LV8.2.1, CAN Frame Receiver Error.vi, I noticed what it does is it makes use of the ncmultiRead.vi and log the messages and displays them. What I am trying to do is to log this msgs and grp the messages according to diff IDs? I want to monitor if the data for the different IDs change and if they change, the change should be logged with the appropriate timestamp. Also I want keep track of the number of msgs that has been broadcasted for the diff IDs. How should I modify the existing vi to perform the functions that I want?
(2,582 Views)
You may group messages according to different IDs by sorting the 2D array in which the data is stored.  Here are a few discussion forum posts about sorting 2D arrays:
Sorting 2D array by col2
Sorting a very large 2D array
Then, in order to keep track of the number of messages for different IDs, you may use functions from the Array palette, such as the Index Array and Search 1D array to count the number of messages.
Rima H.
Web Product Manager
(2,557 Views)
