How can I get the correct format of the VI
Hello Evertybody,
I am just a newbee in labview. I was trying to code just a simple stuff like flipping of four coins and counting them as it turns out be head or tail! I wanted to make a bar chart like number of trials vs number of heads. Can anyone suggest what I am doing wrong?
Regards
Anupam
(3,679 Views)
You want to plot the Histogram h(x) value or just create an indicator for the Histogram Graph out (top right terminal)
Omar
(3,673 Views)
Use the General Histogram vi to get better control on setting the bin sizes
Omar
(3,671 Views)
Hi Omar,
Thank you very much for your reply. Can't I use the waveform graph to do that? I also couldn't find the Histogram graph Indicator.
Regards
Anupam
(3,646 Views)
There is no special histogram graph. Just right-click on the output terminal and select Create -> Indicator. You'll get the graph.
(3,637 Views)
Thank You 🙂
(3,634 Views)
