How can I get the mean of all elements of a 2D Array?
I found a VI to extract the minimal and maximal value of a array, but not the mean. Is there another possibility?
Simon
Using Labview 7.1
(3,395 Views)
Use the Mean function.Smiley Wink
On the function palette, right at the very top, is a button called 'Search'.
(3,394 Views)
Yes I know this, but I can't connect it to the Array! The dimensions are different.
Using Labview 7.1
(3,388 Views)
Reshape Array will convert your 2D array to a 1D array.
(3,382 Views)
Here's an example using reshape array
2006 Ultimate LabVIEW G-eek.
(3,376 Views)
"Mean" is such a simple function, you should make your own. The following code works for 2D, 3D, 4D, etc. arrays. 😄
(You might suggest to NI that "mean" should be made polymorphic with respect to array dimensionality.)
Message Edited by altenbach on 08-03-2006 09:14 AM
(3,371 Views)
