How can I get the run state of a vi?
Hi folks,
within a main vi I open a reference to a subvi, display the panel of this subvi in a subpanel on the panel of the main vi and run the vi there. In that subvi I register for a "value changed" event of a control in the main vi. However, if I want to test the subvi independently while the main vi is not running, I need to drop the registering. Otherwise I get an error message.
How can I check within the subvi whether the main vi is running? In other words: How can I get the run state of a vi from inside another vi?
Peter
Message 1 of 8
(3,599 Views)
You can check if the reference is valid before registering. Otherwise don't register or register for a control you use for simulation.
Felix
Message 2 of 8
(3,593 Views)
Felix,
please, give me a hint. I can't find a method how to check the validity of a reference.
Peter
Message 3 of 8
(3,587 Views)
In the Comparison palette, there is 'NaN/Not A Path/Not a Refnum' Primitive.
Felix
Message 4 of 8
(3,581 Views)
Thanks. But the ref number is also valid if the vi is not running. Apparently I still need an information whether the vi is running or not. How can I check this?
Message 5 of 8
(3,570 Views)
Is your reference passed from the main VI into a control or did you obtain it a different way? Because this way, you will have a refnum on your control when you call it from the main vi once.
But there is an alternative you can use: Application Control Palette has a 'Call Chain.vi'. With that you can check if your vi is called by the main vi or run as 'standalone'.
Felix
Message 6 of 8
(3,564 Views)
Use the VI property Execution>State. Or, simply run it and check the error.
Wiebe.
Message 7 of 8
(3,563 Views)
Thanks a lot, your hints really helped. It works now.
Bye, bye,
P.
Message 8 of 8
(3,551 Views)
