How can I get the serial number of the hard disk of my PC
I want to get the serial number of my PC hardisk. Is there any command that I can pass to the System Exec.vi that will give this info.
(4,522 Views)
I rember this from some time ago. If you use 32 bits system. You will need to do a call to kernel32.dll. And the function is GetVolumeInformationA
http://forums.ni.com/t5/LabVIEW/Call-to-WinAPI-Kernel32-dll-doesn-t-work-in-runtime/m-p/121097 It may do the trick for you
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,511 Views)
On Win, this information should be stored in the registry. So you can read it using the build-in registry functions.
Felix
(4,508 Views)
Whether the volume serial number will be unique ? My requirement is to have a unique identification, of the PC in which I am running my program
(4,500 Views)
Note: its Volume Serial Number, not Hard Drive Serial Number. Obtaining real HDD Serial Number a bit more complicated...
Andrey.
(4,477 Views)
