How can I get the string value displayed on a numeric control that is set for relative time.
I have a numeric control set to display relative time in 30min increments.
I want to record the value displayed on the control as a string.  Unfortunately, when I use the "convert number to decimal string.vi", the resulting string is just the value in seconds.
How can I get the displayed value as a string? (i.e. 1:30 for one hour and thirty minutes)
Sean
Message 1 of 8
(5,357 Views)
If you right click your control and choose properties -> display format and the click the "Advanced editing mode" radio button you will get the format string for the control, something in the line of %<%H:%M>t. You can use this format string with the "Format Into String" function and the just wire the control as input, and you should get your string.
//Martin
CLA
https://www.prevas.se/expertis/test--regulatoriska-krav.html
Message 2 of 8
(5,349 Views)
I've done this:
Message Edited by jcarmody on 01-28-2009 12:01 PM
Jim
Message 3 of 8
(5,339 Views)
I would use M_Peeker's method. jcarmody's method does work, however it is like trying to crack a walnut with a sledge-hammer.
It may be overkill, and you should not add code if you do not need to, it will just slow down the VI.
Cory K
Message 4 of 8
(5,333 Views)
[...] it is like trying to crack a walnut with a sledge-hammer.
I resemble that remark!
I guess I didn't understand the original post.  I played around with M_Peeker's method but got confused, then a person walked by and I got distracted...
Jim
Jim
Message 5 of 8
(5,312 Views)
Accepted by topic author Sean.C
Hi Sean.C!
M_Peeker's suggestion is a good one.  One step that might clear things up is that you need to set the format string input to %<%H:%M>t.
Kristen H.
Message 6 of 8
(5,293 Views)
Kristen:
When I try this, I get an error that I have too many format specifiers?
Greg
v7.1
Message 7 of 8
(5,060 Views)
Hi gstanczak,
can you post what you tried?  Take a look at the Help on Format Into String Function- there's a link under the format string input to the Format Specifier Syntax page (link says "format string") Using this reference will help you get the string you are looking for.
Kristen H.
Message 8 of 8
(5,017 Views)
