How can I have a csv file read from excel to labview.
I suspect that you have your data wired to the graph incorrectly but if you don't post your code we are just guessing here.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 11 of 14
(1,078 Views)
Heres the block diagram, feel free to edit it.
Message 12 of 14
(1,074 Views)
Your are creating an xy graph with a single point at (17; 2) (i.e. two indices).
Please attach some real data and omit all the stuff that's irrelevant before attaching code (e.g. all the stuff from other tabs)..
Why are you micromanaging the code based on the tab state using a case structure?
Message 13 of 14
(1,069 Views)
Heres two files, one is the weather data the other is the radio data. I used the case structure with tab because ithought it would make the code look cleaner. Is is it wrong to do this?
Message 14 of 14
(1,058 Views)
