How can I index the array at multiple locations without using loops?
I have an array of size Nx1 and I would like to return a subset of size Mx1 but Mx1 is not a contiguous subarray of the original set. Is there a way to do this without looping through my set of M and plucking out the points one by one?
Thanks!
Steven
(3,207 Views)
What is it about the elements that makes them a set of the array Mx1? Maybe if I know that I can suggest a method to do what you want without looping through and picking points one by one.
(3,200 Views)
So I have a vector X(N) and I want to multiply say every other element [e.g. X(1,3,5,7,9,...,N) ] by another vector which I obtain in a similar fashion.
In MATLAB, my code would look something like this.
index1 = [1:K:N];
index2 = [1:L:M];
X(index1)*X(index2);
where index1 and index 2 are of the same total length but just represent different indices within X.
Thanks very much!
(3,197 Views)
What is wrong with looping?
If the indices are every other one like you have shown, then you could use decimate array.
(3,192 Views)
