How can I insert my personal steps (create in Teststand) with Labview?
I succeed in inserting steps of TestStand in a sequence via LabVIEW.
Thanks to TestStand I can insert steps that I created me even (I inserted a fichier' ini' in "C:\National Instruments\TestStand 3.1\Components\User\TypePalettes").
Now I would like to be able to insert them via LabVIEW but I do not manage to find them.
Can you help me?
Thanks a lot
(2,391 Views)
So you want to insert your custom step, that you created in Teststand, from within LabVIEW? I've tried this and when I insert a new custom step in the MyTypes.ini and afterwards create a new step from within LabVIEW with activeX calls, it works fine. When you make an activex call to loadAllTypeFiles, and afterwards give the correct Stepname in the createStep activeX call, you have access to the MyTypes.ini and can create a custom step. Just make sure you choose the correct StepName, like the one you inserted in your custom step properties.
Regards.
JV
(2,379 Views)
