How can I invert the output to the data of a serial port after or while writing string data port? (e.g. ITA2 inverted TTY data)
I've converted ITA5 code to ITA2 and send it out the serial port (PC COM1) to a teletype (TTY). My next step is to provide the TTY with "inverted data". Not sure if I should convert the string data to binary and then invert, or is there a way I can invert the bits (levels) at the COM port? The latter is preferred.
(3,946 Views)
Hi
unfortunately I don't have the preferred solution; but a working example for inverted byte. It does not invert the startbit & stopbit !!
regards
wha
(3,945 Views)
Hi, i came over this topic when I did a search for TTY. I have an application that I am trying to automate the mas a manual step using MTTY to communicate over a serial port. Does anyone know if this can be replaced by all LabVIEW code or a call to other software? I would appreciate any help. Thanks.
Terrill
(3,809 Views)
