How can I just use one control-panel to control more waveform graph in one window at the same time
A  data collection system I designed like this.Now,I hope I can watch a waveform during the  time  I want by dragging just one tool ,and the others would locked in the same time-interval.But I don't know how to relating all the graphs
(1,004 Views)
What "tool" are you dragging and how?
Once one graph has changed, the others can be updated to the same properties using property nodes.
Can you attach your vi?
(996 Views)
Thank you sir,the tool I have used is called "图形工具选板",the same is “Graphics tool selection board”.I have tried how to creat a property nodes,but it always couldn't come true .And for my Vi ,I have used some blocks written by other company,so maybe you can't run it successfully
(986 Views)
