How can I keep a listbox on top of a string control?
Brian Beal wrote:
I can lock/unlock, customize, and all that other crap.  What was changed to allow it to work?
Smiley Very Happy lol Smiley Very Happy
Ok, after you unlock, right click, Advanced>>Customize to open the control editor. Now change the control editor to customize mode. Roll the mouse over on the string. You can see that the editor part(text block) of the string is reduced in size Smiley Happy
Message Edited by Vsh on 04-08-2008 09:17 AM
Message 31 of 45
(1,026 Views)
Ben,
what was happening in your machine?..
you would have figured it out by now... Smiley Happy
Message 32 of 45
(1,008 Views)
Since there were no support files with your posted VI, how can customizing the control work?
Message 33 of 45
(1,007 Views)
Dear Vsh,
In the first vi Brian attached, the Visible control works like if it is pressed once listbox was shown and on the next press listbox will get hidden. How to implement in ur vi.
Mathan
Message 34 of 45
(1,006 Views)
Hai Brian,
When u unlock the string control in ur vi, then right click that string control in FP and choose advanced and click on customize. A separate vi window will open with just string control on FP. There you can find one tool in the top left corner menu. click on that to choose between customize and edit modes.
Hope this helps,
Mathan
Message 35 of 45
(1,001 Views)
We are back to square one.  I can't limit the editable area of the string control for my application.
Message 36 of 45
(999 Views)
Dear Brian,
Just press ctrl+M to switch between edit and custom modes.
Hope this helps,
Mathan
Message 37 of 45
(995 Views)
When u got ur string control in customize mode, just move your mouse pointer inside ur string control box, you will see the limited size Vsh mentioned in his attachment.
Mathan
Message 38 of 45
(988 Views)
Just add another event for the "Visible" boolean. and set the visible property of the list box in that event. Smiley Happy
Message 39 of 45
(987 Views)
I do not have time now to figure out why my machine will not let me un-lock the string (LV thinks it is alredy un-locked?)
Brian,
Do I understand you correctly that you need to be able to type in the strng control but you also what the list in front?
AND
You need to be able to type anywhere in the string control?
Ben
Message 40 of 45
(984 Views)
