How can I know if database is corrupted?
Hello Everybody,
I am trying to find out when database is corrupted. I know that database is corrupted but I would like to report this problem from Max to Labview. I know how to solve the problem when database is corrupted but I focus on detect the problem from labview when Max's database is corrupted.
Any ideas will be great helpfull,
Regards.
(2,666 Views)
I don't understand what you are trying to do?  If your MAX database is being corrupted so often that you want to somehow communicate that back to a Labview program, your first course of action should be to figure out what is causing the corruption.  Maybe you should do a clean install of all National Instruments software.  Database corruption is not a normal or expected event so there is no need to try to plan for it in software, IMHO.
aputman
(2,603 Views)
