How can I limit the numbers in labeling an image?
I need to label the parts of an image within a needed size. I don't need to label parts of the images that are too small so how can I avoid including them in labeling the image?
(2,618 Views)
What exactly do you mean by labeling "parts of an image"?  What image?  What parts?  Is this something you are doing as a feature of the vision toolkits?
(2,569 Views)
I'm using the function Imaq Label. I need to label the particles of an image, but I also want to exclude the small particles. Is that possile? Thank you.
(2,559 Views)
Yes its possible.
Method 1: First remove your small particles using imaq particle filter and then apply the label to remaining particles.
Method 2: Compare the particles area and apply the label.
Silver_Shaper | CLD
(2,554 Views)
