How can I load such a long data in labVIEW and convert it from string to array
Dear all
I met with a problem when inputing data to labVIEW
When I try to load a data, which size is 4(columns)*77900(lines) as shown in attahed file, the labVIEW
did not response, How can I deal with it?
After loading it, I should convert it to array, what should I do
Please help me Smiley Sad
(4,694 Views)
Try this in 7.0 format.
(4,684 Views)
Thank you for replying
it works well, but always the size of the data is not known, so it is another problem.
I try to load the files in other ways but it cost a lot of time.
Any more advice?
(4,662 Views)
I try to use "read from spreadsheet files", but only the first column is recognized
The line separater is "\s", I try to replace it with "\t", which means the "tab", but for
such a large file, the repacement seems impossible since the computer did not
response for a long time and I have to restart my computerSmiley Sad
(4,661 Views)
Try this. It reserves a large memory area and then reshapes the array after it reaches the end of the file.
(4,654 Views)
This one is better. It just reads the file and makes it a 2D array of DBL.
(4,646 Views)
Thanks a lot
It woks well, it is interesting to replace the double space with a sigle space
It is not very convinent in labVIEW to restrict the line separater
Many thanks!
(4,632 Views)
