How can I load xcel data into simulate arbitary signal VI
I am using the labview arbitary signal creator , now i have a pattern which can be easily created in microsoft xcel but i need to load the data in the simulate arbitary signal VI so essentially i need to convert an xcel file into a LVM file . Can i somehow load the xcel data as LVM data.
Ams
(2,424 Views)
@Ams wrote:
I am using the labview arbitary signal creator , now i have a pattern which can be easily created in microsoft xcel but...
If you can generate it in excel, it would be even easier to generate it directly in LabVIEW. Are we still talking about the staircase funcion?
http://forums.ni.com/ni/board/message?board.id=170&message.id=221036
(2,420 Views)
