I am looking to save a VI so that when the file is opened in LabView, it will automatically start running. I don't want to make the end user have to click a "RUN" button, as I have a "Power" button that is default on.
If there isn't a way to do that, is there a way to sync the LabView "Run" button with a boolean control? That way, when the run button is pressed, my boolean will go "true". It is already set so that when the boolean is pulled false, the vi stops executing.
-Evan
