How can I make a indicator transparent grey?
Picture control support 1 bit transparent, not 1 byte alpha channel (for translucent).  Just like those old vector image types: wmf, emf, it is limited by the image file format (picture ctrl is a mix of raster image and vector image).
However, it's background, like all other controls support translucent.
George Zou
Message 21 of 24
(737 Views)
Interesting, i'll have to test that when i get home.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 22 of 24
(732 Views)
The emf standard does support gradients and alpha blending:
EMR_ALPHABLEND: This record specifies a block transfer of pixels from a source bitmap to a destination rectangle, including alpha transparency data, according to a specified blending operation.
EMR_TRANSPARENTBLT: This record specifies a block transfer of pixels from a source bitmap to a destination rectangle, treating a specified color as transparent, stretching or compressing the output to fit the dimensions of the destination, if necessary.<18>
It's just that LV didn't catch up.
Message 23 of 24
(696 Views)
Classic controls to the rescue!
/Y
Qestit Systems
Message 24 of 24
(666 Views)
