How can I make a sinosoidal signal to dc signal ?
I need to make a sin signal converted in to a dc signal,how can I do this in LabVIEW pls help me.
Message 1 of 9
(4,026 Views)
Hi tendoraj,
please define your "dc signal"! To ask for conversion of "sin signal" to "dc signal" is way to vague…
Do you need the RMS value of your sine signal? Then just calculate it!
Message 2 of 9
(4,004 Views)
Actually I have made a function generator in LabVIEW  ,and I take a sinusoidal signal from that function generator through NI PXI system using DAQ assistant ,now I want to make that sinusoidal signal to dc signal how can I do this ??
I am using a filter to convert this but this give me a different things.
I have attached my program pic.
Message 3 of 9
(3,993 Views)
Hi tendoraj,
apart from attaching huge image files you still didn't define your "dc signal"! (Do you know how to make screenshots in Windows using PrtScr key?)
What is the input signal (with no filters applied)?
What is the expected output signal after applying any kind of filter?
Message 4 of 9
(3,987 Views)
I know about screenshot but I don't have internet in my system that's why I take a picture,,,ok
And my input signal is a sinusoidal signal ,,,
I want to make it a like a transient response type signal (but it's give me something different type result)
Message 5 of 9
(3,982 Views)
You could pass your signal through a low-pass filter.  As you probably (don't?) know, there is a relationship between the "corner frequency" of a low-pass filter and the "delay" (or "lag") between changes in the input signal and when those changes can be seen on the filtered version.
Bob Schor
Message 6 of 9
(3,960 Views)
Question about what DC formulated in an other way:
The DC 'voltage' should follow what type of information:
Peak value (or amplitude) , RMS value , or ??
Please be more specific what you want to measure.
Some sort of response function?  Like: I exite my device with sine of amplitude A and frequency f  and the response is amplitude ratio (response/excitation)  over frequency?   or response amplitude over exiting amplitude at const. frequency?
Or??
Greetings from Germany
Henrik
LV since v3.1
Message 7 of 9
(3,954 Views)
Yes I pass the signal through the low pass filter,,but still the desired result is not coming,,,it's give me some thing different,,,,what can I do ??
Message 8 of 9
(3,935 Views)
Thanks for your valuable comments,
I need the amplitude value,,i want to make my output curve a constant acrros the time(parallel to the x axis) axis with some amplitude,,,, frequency may be varry but it should be small change,,,,
Message 9 of 9
(3,934 Views)
