How can I make a triangular LED?
I'm a newbie.
Is there an easy way to make a triangular LED?
(5,846 Views)
It depends on what you mean by "easy." I'd just right-click on the control, then go Advanced-->Customize and paste in new graphics. This may or may not be "easy" to you.
Edit: Speak up if you need help doing the above.
Message Edited by DJDDA on 11-19-2007 02:09 PM
(5,839 Views)
Thanks for responding.
I can paste a triangle into the new control panel, but just how do I turn it into an LED?
(5,830 Views)
following please find a shot of a step by step guidance:
1. Place the master LED control on the FP
2. Right click - Advanced - Customize;
3. Left click on the spanner (-> customization mode)
4. Right click in the center of the LED -> Picture Item: Notice that there are four images: on, off, transition on->off (mouse button pressed); transition off->on (mouse button pressed); All four images have to be replaced to get a smooth control
5. Choose picture item 1 (2,3,4)
6. To replace the current image (e.g. green circle or rectangle) choose one of the available options which are listed in the right click menu -> "Import Picture from Clipboard", "Import from File", ...
You need at least two different triangle images (for example light and dark green with a gradient to get a 3D effect)
7. Repeat step (4) and (5) to replace all picture items
8. Adapt/Replace the shadow of the control to complete the 3D effect.
(5,805 Views)
I get it!
THank you so much for taking the time to explain it to me.
(5,797 Views)
thanks to THsa ...
(5,385 Views)
