How can I make an area of the front-panel have scroll bars?
rthorpe,
My appologies..    The anti-senility drugs stopped working.
I was reading another post, yet my reply went to this one.
As I wrote my last post, I had not gone back to the top.
Sorry for the confusion..  I'll get my prescription renewed with increased dosage..
Message 11 of 21
(2,335 Views)
So you basically only want 1 cluster to have a scroll bar? Then you can place a free scroll bar on the panel and in the event (probably) ... no, no property for that.
To solve it like you want to, you'll have to insert the cluster in a sub-panel. Though i'd still suggest tab control, you can probably find some nice grouping logic if you look again. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 21
(2,329 Views)
rthorpe wrote:
How do you control the x,y value of the control within the cluster?  I've tried doing that with the property "top" but that doesn't seem to work.
Actually, that should work. Just make sure you create the property for the control which is inside the cluster. It would probably be easier if you put another cluster inside the first cluster and put all the other controls into that cluster, because then you only have to move the cluster.
Basically, this methods simulates a scrollbar by moving the content up and down instead of moving the origin.
___________________
Try to take over the world!
Message 13 of 21
(2,328 Views)
Accepted by topic author rthorpe
And just because I was bored (LV 8.6).
___________________
Message 14 of 21
(2,315 Views)
Smart Tst, didn't think of moving all items in the cluster, although it feels kindly of a heavy workaround. Maybe scrollbars is something for idea exchange?
/Y
Qestit Systems
Message 15 of 21
(2,310 Views)
Thanks a lot everyone
Message 16 of 21
(2,306 Views)
It's already there, although personally I prefer the second idea, which is tabs inside clusters, but there's no reason we can't have both:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Scroll-Bar-Property-for-Clusters/idi-p/921174
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-clusters-to-have-quot-pages-quot/idi-p/1481862
___________________
Message 17 of 21
(2,293 Views)
Hi everyone! I have the same problem, i want a cluster with a scrollbar but the example given is created with LV 8.6 and i am using LV 8.5.
Could anyone revert it to my version? Thank you very much for your time.
Message 18 of 21
(2,252 Views)
In LV 8.0.
___________________
Message 19 of 21
(2,240 Views)
Thank you very much!
Message 20 of 21
(2,231 Views)
