04-08-2011 07:39 PM
04-09-2011 12:54 AM
04-09-2011 03:08 PM
I saw a project wher solved that problem (listbox with combobox but this example is too difficult for me)
04-09-2011 08:52 PM
Sorry, I should have phrased my response differently. You can make it appear as if they are in the listbox, but you can't actually put them in the listbox.
Was the example you looked at this one?
If not, have a look at it. If so, explain what confuses you and maybe you can be pointed in the right direction. There are probably ways to do this more simply, without all of the extra fluff that the code uses to add more complex capabilities.
