How can I make this vi to write into ms access?
I had this sub vi and I need to make it work so that it writes data in Microsoft access. Write now it writes data into notepad. Please if anybody help me out?
(3,008 Views)
You either need to use ActiveX or use the Databse Connectivity Toolkit (extra $).
(2,999 Views)
It certainly does not write to Notepad unless you are doing soemthing pretty fancy in the missing subVI. You are probably just creating a text file that Notepad can open.
In order to write to a database, you can use the Database Connectivity Toolkit or something like LabSQL.
(2,995 Views)
Thank you for replying that but I think I can use TDMS files and write into it and then use that in ms access. I was taught this in labview core 2 class. I am confused
(2,992 Views)
Yes you are write , its a text file which opens with notepad. Sorry I did not clarify over that.
(2,989 Views)
(2,976 Views)
Thank You for replying i will try and doing that .
(2,964 Views)
