How can I measure C(V) of a MOSCAP with HP4140B pico-ampmeter ?
I am trying to develop a program in labview to measure the high and low frequency on Metal oxide structure for C(V) measurement.
I am trying to use the HP4140B pico-ampmeter and Keithley 199 DMM scanner with PAR410 C-V plotter.
 I would like to know how i can program labview to communicate with HP4140B and Keithley 199DMM and read the C(V) measurements. Please assist and guide me for the same.
(2,588 Views)
There are unsupported drivers for these ancient instruments - 4140B and 199. Go to the Instrument Driver Network for information on what a driver is and how to use one. You will need a GPIB controller from NI.
(2,581 Views)
Thank you Dennis Knutson. I have found the required drivers and created a prototype of the C(V) measurement program. But right now the problem I face is that even though it inputs the parameters correctly.. it doesnt read the output right. I get a straight line for the C(V) output graph. attached you can find my program for Quasi-static C(V) measurement.
(2,575 Views)
