How can I modify individual DaqMX channels?
I am creating an analog input task using the "Create Virtual Channel" VI, in RSE mode.
How would I modify some of these channels to use a different mode (differential) or a different max / min voltage?
If I create a channel property node, can I wire a string constant into the "ActiveChans" terminal, and then set whatever properties I want? If not, how would I specify the channel(s) I want to modify? Any help would be greatly appreciated!
(2,505 Views)
Tritone,
You are absolutely correct. You can use a DAQmx Channel Property Node to modify the properties of individual virtual channels within a task. You can also use a DAQmx Task Property Node to obtain an array containing the names of all of the virtual channels within a task.
Good luck with your application.
Spencer S.
(2,505 Views)
