How can I modify the Stile of a String-Indicator (without the Frame)?
I only want to see the Text-String on the Frontpanel,
without the Indicator-Frame.
(2,676 Views)
Go to the Classic Controls palette, select a Simple String indicator. Then use the paintbrush tool with transparent selected (The T in the upper right hand corner of the color palette) to make the indicator transparent. The text in the indicator will still be visible, but not the indicator frame or background.
(2,676 Views)
Color it Transparent (T) with the color tool.
"Klaus10" wrote in message
news:5065000000080000002EAA0000-1066448259000@exchange.ni.com...
(2,676 Views)
