How can I monitor the DIO Buffer in non regeneration mode
I have an application where I'm feeding samples into a USB 6341 devices in non regeneration mode and want to know how to monitor how many samples remain in the buffer until it runs out. Is there a way to monitor this?
(2,800 Views)
Have a look at the "Status" properties in a DAQmx Write property node.   There's one called "Space available in buffer."   Subtract that from the buffer size to see how close the buffer is to running out of fresh samples.
-Kevin P
(2,765 Views)
Where do I find that?
(2,760 Views)
In the DAQmx palette, pick the icon labelled "Write Node".  Once it's on your block diagram, the drop-down menu will let you pick "Status" and show the sub-menu where you can pick "Space Available in Buffer".
-Kevin P
(2,752 Views)
